Portable DVD Screens
Discussion in 'Plasma TVs Forum' started by Canary_Jules, Jul 27, 2004.
  1. Canary_Jules
    Canary_Jules
    Jan 25, 2003
    3,394
    2
    Leicester, UK
    +963
    OK, I posted this on the DVD players thread without reply so thought it might be better off here. Hope I don't step on any one's toes! I just bought a Mustek PL207A portable DVD from Ebuyer and am very happy with it. There's one small fly in the ointment though! There's a bad pixel near the centre of the screen. It's not glowing green or anything, but appears slightly darker than rest. Since this is my first portable I just wondered what the tolerance rate is for dead pixels on portables. When would you send one back for having a dead/stuck pixel? Should I really expect a perfect LCD picture from a budget portable? You can tell that I'm still deciding what to do on this one so advice would be appreciated.
    Jules
  2. rooney
    rooney
    Mar 7, 2004
    506
    midlands
    +33
    i dont own 1 but i buy loads of stuf from ebuyer if you are not happy with it put it back in the box send it back and get a new they are prety good on stuff like that.
    also noted that argos are doing a portable dvd player for £99
