portable dvd problems
Discussion in 'Video Streaming Boxes & Services' started by lar113, Dec 28, 2004.
  1. lar113
    lar113
    I received an Alba portable DVD for Xmas and I'm having difficulty getting it to work through the TV. Can anyone help? I've followed the instructions for connection with and without a scart connector and I've tried it on 3 TVs now. Is there a really simple thing I'm missing? With ordinary DVDs as soon as you connect and switch on it takes over from the TV and loads automatically but I just can't get the protable to do the same. Has anyone solved this problem?
  2. o THE CHAD o
    o THE CHAD o
    Nov 22, 2003
    1,480
    London
    +83
    try pressing the av button on your tvs remote.ie selecting the scart channel manually
  3. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    22,623
    2
    In a secret location with Jennifer Lawrence
    +9,333
    Moved to DVD Players forum
  4. broxy
    broxy
    I have a venturer model and have the same problem connecting to the T.V(I'm also selecting the A.V channel)
  5. bowler900
    bowler900
    Jun 19, 2004
    90
    Downham Market, Norfolk
    +7
    Most portable DVD's do not use scart for transfer of video information they use composite video with possibly a scart type plug on the end, this is unlikly to carry pin 8 which carries out the auto switching function, many cheap scart leads also fail in this manner as to save money they only use 4 wires not the fullscart compliment.
