Port Bungs
Discussion in 'Home Cinema Speakers' started by GliderRider, Jan 2, 2005.
  1. GliderRider
    GliderRider
    Dec 17, 2004
    119
    16
    London, Middlesex
    Just bought some Kef Q7's, can someone tell me what the Port Bungs are for?
    Andy
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    They're supposed to be for "tuning" the port for smoothest bass response. I have them with my Mission speakers too, but they sound OK without the bungs, so I've never bothered with them.
  3. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
    As Nick's already stated, plus, they're very usefull if you have to put the speakers close to walls. Helps to reduce the 'Boom'.
  4. Malky1903
    Malky1903
    Jul 2, 2003
    1,937
    48
    Aberdeen
    +64
    As already mentioned above but the Q range is designed to be near walls hence being front ported. I have Q4's and can't tell the difference when the bungs are in or out.
  5. GliderRider
    GliderRider
    Dec 17, 2004
    119
    16
    London, Middlesex
    Thanks all. I can't tell the difference, but wanted to check in case I was missing something.
    Cheers :smashin:
  6. Londondecca
    Londondecca
    Dec 21, 2003
    2,102
    +104
    The port should allow for deeper bass but dependant on location etc can lead to some booming, the bung should slightly reduce the bass extension but give a 'tighter' bass. I would say unless you have a bass problem, it is a matter of personal preference. These things are much easier to hear with music than films
