Poroblems with surround
Discussion in 'AV Receivers & Amplifiers' started by Deadstar, Jan 17, 2008.
  1. Deadstar
    Deadstar
    Jan 10, 2008
    20
    Hello,
    I finally bought my center and suround speakers :clap:
    Only one problem, the surroud speakers doesn't work :thumbsdow
    They work, because when I use the speaker test function on my Denon AVC1-A1D amp al the surround speakers work and make noise when they have to make noise.
    But if I watch a DVD (Pink Floyd Pulse), I put my amp on dolby surround and set the DVD on 5.1 in teh audio menu. I select the speaker test and the fornt speakers and the center work great. But when the test comes to the surround speakers, it produces the sound in the front speakers, and not the surround.
    I connected the DVD player, with a RCA cable (stereo) to the DVD input of the amp. Do I need to make an other connection? I have a JVC DVD player ans it has got all the DTS/Dolby logo's on it.
    :lease: help me.
  2. bsuttie
    bsuttie
    Apr 4, 2006
    1,545
    63
    Edinburgh
    +206
    In order to get 5.1 you need a digital connection, either optical or coaxial. You can't get 5.1 over a stereo analogue connection.
    regards
    Brian
  3. Deadstar
    Deadstar
    Jan 10, 2008
    20
    :oops: sounds pretty logic thanx
  4. qwerty1234
    qwerty1234
    Aug 21, 2006
    608
    28
    HERTFORDSHIRE
    +53
    this is your problem.your only putting a stereo source in to the amp. you need to be connecting the DVD with either an optical connection or a digital phono. this will feed the 5.1 sound channels in to the amp.
    with a steroe source put your amp in to prologic and you'd get a surround experience but this you'd only really use for tv.
  5. Deadstar
    Deadstar
    Jan 10, 2008
    20
    I also tought that the sound of the center peaker sucked. It sounded like it sucked my whole stereo front speakers empty. Can this also be because of the RCA cable. Or should that one work fine? And does it just suck?
    (It is a Focal Cobalt CC800)
  6. qwerty1234
    qwerty1234
    Aug 21, 2006
    608
    28
    HERTFORDSHIRE
    +53
    i'd get rid of the rca then reevaluate.
  7. Deadstar
    Deadstar
    Jan 10, 2008
    20
    I have a yellow output on my DVD. For digital. It looks the same as the RCA outputs. Is that Optical or Coaxial? :S
    Sorry lost the manual.
  8. MarkTaylor
    MarkTaylor
    Feb 28, 2002
    4,328
    +662
    That is a composite video output, nothing to do with sound.
    Tell us the model number of your DVD and we can be of more help
    If they have coloured the digital output yellow and it looks like RCA then it is co-ax not optical
  9. Rom
    Rom
    Aug 16, 2007
    2,064
    116
    Sheffield
    +746
    If it is yellow, it is probably composite video. That won't work. It is more likely you have optical on your player - it seems to be more common than coaxial. Look for a small square plug on the back, about 5mm square. That should be optical. You would obviously need an optical cable too.
  10. Deadstar
    Deadstar
    Jan 10, 2008
    20
    Ok sorry it sometimes helps to look at tha back of a machine.
    It had got a small round input (redish) that says: PCM/ digital out. And... coaxial :oops:
    THNX for the help
    Edit: No more brownish ( I wonder if there is a name for that color at all :S)
  11. qwerty1234
    qwerty1234
    Aug 21, 2006
    608
    28
    HERTFORDSHIRE
    +53
    should be orange but it sounds right you would then need the same input on your amp.
