" Popping " Subwoofer/Amp - DS1233
Discussion in 'Subwoofers' started by mrdbristol, Aug 26, 2005.
  1. mrdbristol
    mrdbristol
    Aug 4, 2005
    15
    Slight annoyance with my set-up
    Acoustic Solutions DS1233 Home Cinema connected to VCR , DVD + Digi-box + Samsung Analogue TV
    On normal Digital TV listening ( output through the Digi box's RCA Audio outs )
    there is a " double pop " noise when a program switches to an advert or from advert to advert. No problem with continuous listening during programs , only when programs start/stop i.e commercial breaks.
    This popping noise only comes from the sub unit.
    Sub is about 12" from TV
    Any suggestions how to cure this ?
  2. MACKY
    MACKY
    why dont you in turn disconnect each device eg. dvd player, then video and then sky to see if the problem continues..then connect the problem device in a different way if possible.(maybe try scart from digibox)from check also your connection to your sub.
