Popping sound on some MPEG files? Please help...
Discussion in 'Computer Components' started by janmars, May 25, 2003.
  1. janmars
    janmars
    May 4, 2003
    162
    When playing back certain MEPEG files, I am getting popping sounds, this is usually accompied (sp) by slight picture break-up. This never seems to happen AVI files though.
    I have tried a number of players all with the same result. Any ideas?
    Cheers...
  2. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    You say that it only happens with certain files... did they ever play ok? What are they like on other machines? You could try making sure all your codecs are up to date... see the indirect link in my post here :)
