neilalford
Established Member
- Joined
- Dec 1, 2010
- Messages
- 120
- Reaction score
- 5
- Points
- 54
Great thanks, the idea about setting the initial share on the SSD and then adding the main share using NMJ Toolbox sounds like it will do the trick.
If you are installing the forum release firmware you have to manually update nmt apps. when you download a forum release inside is nmt.apps put that on a root of usb and click usb install.
also note if this is a first time install sometimes it wont do an online install and same steps apply
Thanks for reply so another question is it possible to change pch a-400 menu skin ?
- Added "Right Eye First" Setting
Dont work on .iso ?? crap!
It works with iso files.
Can confirm that the network drop issue is not fixed with the latest firmware. Still having to power off and on again every day due to it.
Rom said:There is a way to get the DB on the SSD. Set the NMJ up to scan the SSD as a media drive first (which will make it create the DB on the SSD) then use NMJToolbox2 to add the proper share to the database and rescan (I would recommend scanning with NMJToolbox2 as it tends to be faster).
As to YAMJ, there is an IPad/Android add-on for it called iSkin. You will also have to use Eversion with yamj to enable flash support as the standard YAMJ install is HTML - which the A400 does not support).
Not sure if anyone else has noticed but the mods on the community support forums really have got a bug up the backsides and frankly some of the replies are so unprofessional its dumbfounding
