POP ups POP ups POP ups!
Discussion in 'PC Gaming & Rigs' started by jamesrickards, Apr 21, 2005.
  1. jamesrickards
    jamesrickards
    Seriously my computer @ work is plagued with them, every time i open google i start to type something and then bang !
    888 casino pops up ..i would appreciate any help on stoping aNY POPUPS!
    IM USING XP WITH SERVICE PACK 2
    CHEERS IN ADVANCE!
  2. SGhosh
    SGhosh
    id suggest getting a program called adaware to flush out your system for adware and stuff. ofcourse it may not completely eradicate the problem, so you may need to try other programs like webroot spysweeper. finally it would be good to run a virus scan.
  3. davet010
    davet010
    Jul 23, 2004
    384
    +10
    couple of things..
    try using Spybot or Microsoft Antispyware..both are free.
    Instead of using IE6 as your web browser, try Mozilla Firefox, which is better at filtering out the popups
  4. Joe Pineapples
    Joe Pineapples
    Oct 23, 2001
    6,748
    Doncaster
    +868
    you can also use a pop-up blocker (after removing spyware), such as the one which comes with google search bar. I used to use that with IE, and quite effective it was, before i moved to firefox which has its own pop-up blocker built-in (as stated above)
  5. Garrett
    Garrett
    Apr 21, 2001
    33,628
    2
    167
    The best thief you’ll never see.
    +4,483
    Yes Google search bar is good, dont forget to switch it of for this site though as you will not get PM's.
  6. jamesrickards
    jamesrickards
    Many thanks..
    Ive just got into the office and i have dwonloaded SPYBOT and HEY presto!
    No pop-ups!
    cheers! .....now can anyone tell me the meaning of life ??
  7. Mr.The.Spoon
    Mr.The.Spoon
    Jun 12, 2003
    524
    I'm a Londoner.
    +13
    Well since we all know the answer (and if you don't, just go to the cinema next Friday), the meaning must be part of the question. The whole of life is a game of Jeopardy.
  8. maverick177uk
    maverick177uk
    Jun 1, 2004
    3,805
    103
    +491
    42 :D
  9. Mr.The.Spoon
    Mr.The.Spoon
    Jun 12, 2003
    524
    I'm a Londoner.
    +13
    No, as I just said, that's the answer, not the meaning!!
  10. jamesrickards
    jamesrickards
    OH GREAT :(
    just when i thought the pop ups had gone BANG !
    AURORA anyone? all the pages open up with the 'AURORA' in the top left hand corner!!
    Back to square one :(
    :lease: HELP
  11. johndon
    johndon
    Feb 3, 2002
    1,930
    48
    +89
    Spybot would get rid of any existing spyware that was causing popups but it's not the only cause. To stop them from now on, get the Google toolbar or Firefox - I've used both and have no problems with popups.
    John
  12. Joe Pineapples
    Joe Pineapples
    Oct 23, 2001
    6,748
    Doncaster
    +868
    fi you havent already, download the microsoft (beta) anti-spyware utility (as suggested by Davet010). It can usually find quite a few spyware programs that other utilities miss. Just make sure you update it after downloading, and also do a 'deep' scan.
    joe
  13. FoxyMulder
    FoxyMulder
    There are so many sites putting spyware on your computer that not any one program can get rid of them, my advice is have several different programs on your computer, run em all and you will find you can minimise spyware but never totally eliminate it.
    Worth noting i have AOL and it has a popup blocker on its web browser and it works perfectly and as someone already said the google toolbar is worth getting for internet explorer ( needs configured once you get it ) Mozilla Firefox is a great browser.
  14. jenic
    jenic
    Dec 10, 2004
    2,871
    83
    +179
  15. jamesrickards
    jamesrickards
    Cheers All .. Ive Used Adware.spybot And Now M.soft Beta Spyware Thing..
    I Will Try Firefox!
    **groan!**
