could anyone tell me if sands of time from psn store is in 5.1 sound i can only get it to play in stereo ....had a look round net but cant find a answer
I believe the game doesn't support dolby digital 5.1 only LPCM 5.1 basically you have to be connected to your amp via HDMI to get it optical cables don't have the bandwidth to do LPCM 5.1, if your Amp cant use HDMI only optical then then game will just default to stereo which according to some is the better option as the 5.1 mix isn't good, i dunno if the 5.1 mix is good or not as i haven't got the game to test that.
