Poorly Panasonic
Discussion in 'Panasonic TVs Forum' started by gingerone, May 24, 2004.
  1. gingerone
    gingerone
    Dec 10, 2002
    2,581
    +402
    I've had my panny th37pa20 since january and today it has started switching itself off every forty minutes or so and the standby light flashes.
    The only way to get it back on is to switch it off and then switch it back on again.
    Also as it switches off and when you switch it back on there is a high pitched noise as well as it taking longer and longer for the picture to come back on when I start it back up (the picture is extremely dark until the high pitch noise stops).
    Anyone had the same problem or know what might be causing it?
  2. nobbydog
    nobbydog
    Jun 19, 2003
    262
    Comfy basket in the utility room
    Welcome to the 'shutdown Club'. Its the power supply board, it will need a 15 minute in home repair by Panasonic.
  3. nickc
    nickc
    Oct 31, 2002
    33
    Yep, i'm a member of that club too :eek:
  4. gingerone
    gingerone
    Dec 10, 2002
    2,581
    +402
    Cheers lads, I'm waiting for an engineer to call for an appointment.
    Curiously it was happening all the time yesterday but last night I managed to watch return of the king with no problems and it has not happened yet today.
    I was starting to think it was an overheating issue as the plasma is in front of the window.( although yesterday was no where near as hot as last week and I had no problems then!).
    I'll let you know how I get on with the engineer but out of interest, those of you who have had the problem was it always shutting down or was it sporadic?
    edit: Well I spoke too soon it's started again and yes the led does flash seven times!
  5. nobbydog
    nobbydog
    Jun 19, 2003
    262
    While you are waiting for the repair, shut all picture levels down to min., put all the power save options 'on', etc. I found that this would somehow protect it from shutting down and would allow virtually uninterrupted veiwing, albeit with a crap picture, but better than no picture!
  6. gingerone
    gingerone
    Dec 10, 2002
    2,581
    +402
    I'll give it a try, I'm getting annoyed now, I was assured that the engineer would call me today but no call!
  7. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Here is a thread on the subject. They are good once you get hold of them. It's Panasonic who hold things up.
  8. gingerone
    gingerone
    Dec 10, 2002
    2,581
    +402
    Thanks Maw, I've contacted the engineers direct and I have an appointment booked.
    Cheers!
