Poor skin tones and colours on Sony KDE....37 Plasms
Discussion in 'Plasma TVs' started by mattflukes, Mar 19, 2005.
  1. mattflukes
    mattflukes
    hi there
    hope you can help. we just bought a sony KDE...37 plasma for 2,500 and are diasppointed with the picture quality. COlour tones are poor, and with skin tones, and around lights instead of it being a smooth colour you get almost rings around them.
    We have played with the settings, looked at the input (cable) and can't seem to resolve it. Any ideas? Is it a fault with the plasma or is there something that will fix this?
    Many thanks for any advice !
  2. stu954
    stu954
    Settings I have are : Contrast 45, brightness, colour and sharpness all at 50.Noise reduction to "off". colour tone to " cool " and drc mode to high density". If you have this problem with all sources then maybe you have a faulty unit.
  3. zAndy1
    zAndy1
    Nov 26, 2002
    19,356
    2
    5
    163
    +6,467
    Oh dear... and to think you could have had a 37" Panny 7 series for £1500! If you've only just bought it send it back for a refund and get the Panny and have a holiday with the grand change...
    Andy
  4. Ymegod
    Ymegod
    Nov 14, 2004
    175
    Bromley, Kent
    Bit rich coming from somebody who is prepared to list a Sanyo projector and Philips DVD Recorder amongst his prized possessions.
  5. zAndy1
    zAndy1
    Nov 26, 2002
    19,356
    2
    5
    163
    +6,467
    Oh yeah... have you seen the Sanyo Z3 in action at all? Bet you bloody haven't or you wouldn't have made a daft comment like that! All I was saying was there was a damn sight cheaper way to get a 37" plasma (and a good one at that) than spending £2500 on the Sony.
  6. superpixel
    superpixel
    The cheapest price for the Sony 37XS1 is £2100. If you want a Sony with a similar picture to a Panasonic Viera then the 37M1 is £1600. The Sonys aren't/weren't poor value if you care to look objectively. I say were'nt as its all change in the consumer TV market in the next few months...
    Colour accuracy and skin tones on the 37XS1 are superb - among the best you can get, and leaps and bounds ahead of those Panasonics in that department. If your set looks poor on default settings and on all sources, then you have a faulty unit or just have strange eyes!
    As for the 'ringing' this could be either due to digital artefacts from the signal, or the plasma itself. How does analogue TV look?
  7. Ymegod
    Ymegod
    Nov 14, 2004
    175
    Bromley, Kent
    Oh dear.... I appear to have touched a nerve. Of course I have seen a Sanyo Z3 in action or I wouldn`t have made a comment like that. What about the Philips DVD Recorder ?
    Perhaps I misjudged the tone of your post. I suspected irony where , obviously, there was none intended.
    It would have been better had I explained as Superpixel has rather than trying to defend somebody in need of assistance other than to suggest an inferior product and a holiday !
  8. phil5743
    phil5743
    Apr 13, 2003
    401
    28
    Ongar, Essex
    +27
    I'll confirm how superb the Sony PQ is (mine was set up for DVD using the DV Essentials DVD - search elswhere on this site) - not to mention the great looks also! Only shame is that it won't be compatible with Sky HD as the resolution is easily up to the job - not so existing cheap Pannys.
