Poor signal quality in Bradford anyone else?
Ayub
I get the chirping box, the "engineer" states the signal from the box is fine. I disagree anyway the box was changed ( it was only 1 month old) and the new box has started playing up too.
Virgin is getting worse, yes worse!
Ayub
At my end, he put his signal tester i think it was 3db. he did say it was ok, i'm going to ring them today and gat another engineer out.
Ayub
Just at the tv point. TBH I shouldof checked the reading :( i feel like an idiot now.
DougEdey
I was told my signal was weak at that point, I just wanted to see if they tested it before anything got split at all. If it's the same issue each time spend a while with the CS and get them to send an engineer out again, when (s)he comes ask if they can boost it at the transmission point and/or check the cable
