Poor signal due to magic eye
Discussion in 'Satellite TV, Sky TV & FreeSat' started by daiharrison, Jan 10, 2012.
  1. daiharrison
    daiharrison
    Apr 13, 2010
    3
    Swansea, UK
    I have a sky hd standard set up with a link to bedroom upstairs.
    I have perfect quality of picture when I put the lead direct into the tv, however when it is put through the magic eye the picture quality is very poor!
    I am using a SL Link Magic Eye and used two different ones.
    Can anyone suggest a better quality Magic Eye?
    Moony thanks
    Dai
  2. logiciel
    logiciel
    Feb 2, 2008
    53,020
    UK
    +5,729
  3. daiharrison
    daiharrison
    Apr 13, 2010
    3
    Swansea, UK
    apologies - i downloaded the Ipad app last night and posted using the app. I did get a little lost, certainly not as easy to navigate as a normal webpage.
  4. Stevenage Neil
    Stevenage Neil
    Jul 14, 2008
    9,826
    +897
    The Eye will not be at fault - more the connection between the Eye and your TV. Check the connectors/cable from the Eye to the TV. (As a test plug the Eye directly into the TV)
  5. MartinPickering
    MartinPickering
    Sep 23, 2009
    4,953
    Greek Island
    +507
