Poor reception with sky magic eye
Discussion in 'Sky Digital TV Forum' started by AngryDog1981, Jul 30, 2012.
  1. AngryDog1981
    AngryDog1981
    Oct 7, 2009
    222
    16
    I've just fitted a sky magic eye onto my upstairs tv and ran a cable from the back of the sky+ hd box downstairs.
    I do not have any other aerial plugged into the back of either tv or the sky box.
    The reception on the upstairs tv is grainy. I have it set at channel 25 on the rf output, but tbh it's the same on all the channels that I have tried up to now.
    Am I just going to have to put up with it?
    I am in hull if that matters?
  2. Tight Git
    Tight Git
    Mar 3, 2004
    6,331
    +597
    Forgive me, but are you aware that the Magic Eye is used only to send back information to the Sky box?
    (Lots of people think it sends the picture to the remote tv.)
    So, suggest you start without the Magic Eye and see if you get a decent picture.
    If not, change channels on both RF2 o/p and remote tv until you find a clear channel.
    Assuming you find one, then add in the Magic Eye.
    If not, suspect the extension cable.
    Please come back if you require further information.
    It certainly does! :laugh:
  3. logiciel
    logiciel
    Feb 2, 2008
    53,163
    UK
    +5,788
    As you don't have an aerial connected it doesn't matter for the problem, but it IS interesting.:D
    If you did have an aerial it would matter a lot as 25 is a Freeview channel there, which is also here.;)
    Try channel numbers in the forties, and check the connections on the cable.
    T G's point is that you don't get "reception with magic eye", you get it with the cable.
  4. Tight Git
    Tight Git
    Mar 3, 2004
    6,331
    +597
    Thanks for the clarification, Logi. :smashin:
    Well, I knew what I meant! :D
  5. logiciel
    logiciel
    Feb 2, 2008
    53,163
    UK
    +5,788
    Two heads....;)
  6. MartinPickering
    MartinPickering
    Sep 23, 2009
    4,953
    Greek Island
    +507
  7. Stevenage Neil
    Stevenage Neil
    Jul 14, 2008
    9,826
    +897
  8. MartinPickering
    MartinPickering
    Sep 23, 2009
    4,953
    Greek Island
    +507
    I took the trouble to write the darn thing. I'm not going to retype it in every thread!
  9. logiciel
    logiciel
    Feb 2, 2008
    53,163
    UK
    +5,788
    It's really us who should be posting it - maybe we should take it in turns?;)
  10. MartinPickering
    MartinPickering
    Sep 23, 2009
    4,953
    Greek Island
    +507
    Yeah, I realise I'm doing your job but there's no "poke" facility to remind you. ;)
  11. Stevenage Neil
    Stevenage Neil
    Jul 14, 2008
    9,826
    +897
    AV Forum rule 1?
  12. logiciel
    logiciel
    Feb 2, 2008
    53,163
    UK
    +5,788
    7;)
