poor quality panasonic
Discussion in 'Plasma TVs' started by THE BOARS, Nov 26, 2004.
  1. THE BOARS
    THE BOARS
    Nov 25, 2004
    3,887
    68
    +79
    hi having problems with my panasonic 42 30 are there any known problems with poor quality picture ie even with dvd the picture is grainy having to turn the sharpness right down
    also any hints on the settings ie brightness half way
  2. ian harland
    ian harland
    Hi, are you swapping your sources, using the same cable or are they all connected using different cables.More to the point, what quality are the cables you are using?
  3. THE BOARS
    THE BOARS
    Nov 25, 2004
    3,887
    68
    +79
    squart lead for cable digital [think its called that cost £50 ]
    have component leads [good quality] for my denon2900 dvd player
