poor quality AVI
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by dan76n, Oct 12, 2003.
  1. dan76n
    dan76n
    May 12, 2003
    88
    australia
    hi all, Im getting closer to home movies on disk but i still seem to be getting poor quality AVI files, i know Quality isnt meant to be top notch on pc but im far from the quality i get when watching on pc without capturing. any advise
  2. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    Are these poor quality .avi's captured from digital or from analogue ?
  3. dan76n
    dan76n
    May 12, 2003
    88
    australia
    DIGITAL
  4. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    Digital should just be a bit for bit transfer so quality shouldn't be worse.
    Have you tried capturing back to tape that which you have captured & ensuring it's OK then ?
  5. owenw
    owenw
    Jul 19, 2003
    269
    Ireland
    As long as you're capturing to PC and transferring back to the DV camera with the FireWire / iLink cable you shouldn't have any visible loss in quality.
    However if you use the S-Video or Composite Video (analogue) connections to connect to DV camera your video capture card, expect some loss in quality.
    I think USB video transfer is low resolution too, on cameras that support it?
    Finally your PC's speed, video card, amount of RAM, hard disk speed etc. will affect the smoothness of playback on the monitor (frames per second).
    Some video cards are pretty useless when it comes to showing real-time video when you're editing.
    Also remember your PC monitor is a progressive scan (non-interlaced) display whereas the footage from your camera is interlaced so it won't be as smooth as on a TV screen.
