Poor picture through dvd recorder from sky..help please
Discussion in 'Blu-ray & DVD Players & Recorders' started by start!, Feb 27, 2005.
  1. start!
    start!
    Feb 26, 2005
    90
    I've not posted for a while and for some strange reason i've had to re-reg again because it didn't recognise my username etc,anyway back to my problem.....
    I got a goodmans 301r dvd recorder today and connected it to my tv and sky decoder as follows (i've also tried loads of other variations):
    DVD RECORDER 'scart in' socket connected to SKY DECODER 'vcr scart' socket
    DVD RECORDER 'scart out' socket connected to TV 'av1' socket
    SKY DECODER 'tv scart' socket connected to TV 'av2' socket.
    When i press the 'source' on the dvd remote and select 'scart' so i can record directly from Sky via scart connection the picture appears to be kind of distorted and the colours aren't right, its as if its not tuned in correctly.Sky looks perfect if i just watch it through the tv.
    i've tried using scart leads but it hasn't made any difference.
    please help me sort out my new toy
    thankyou for any help.
  2. Kwozzii
    Kwozzii
    Jun 29, 2003
    295
    Northants
    +16
    Don't know if the scart input on the back of the dvd recorder is RGB capable or not.....
    At the moment the way you've got it connected - DVD RECORDER 'scart in' socket connected to SKY DECODER 'vcr scart' socket - you're only recording in composite which could explain the poor picture.
    If the dvdr scart in takes an RGB signal the you want Sky tv out > dvdr scart in and you would then use the dvd as a pass through, and put the Sky vcr out > TV AV2...
    Kwozzii
  3. start!
    start!
    Feb 26, 2005
    90
    I really don't know anything about these things so i've no idea whether its RGB capable or not.
    I tried connecting it like you said but don't seem to get any sky through the dvd recorder now.
  4. Kwozzii
    Kwozzii
    Jun 29, 2003
    295
    Northants
    +16
    In that case I would change it back to how you had it before - it doesn't seem like you dvdr can accept an RGB signal at the scart input.....
    Kwozzii
  5. start!
    start!
    Feb 26, 2005
    90
    thanks for your help Kwozzii , here's my update.
    In the dvdr on screen settings it does let me select RGB so i don't know if that means it will accept it or not.
    Anyway instead of connecting sky via the scart,i've conneted a video recorder instead.
    The picture from this comes through perfect so it obviously doesn't like sky.I think i'm going to have to take it back to the shop.
  6. Wackojacko32
    Wackojacko32
    Jan 6, 2005
    239
    Pinxton, Derbys
    Start!
    It will let the video through as this is Composite feed also. If you are able to set the Scart in to RGB then it should accept RGB sources. Your problem may be that someone has pressed the TV button on the Sky remote as this sets the output back to composite. Try pressing Sky button with the TV scart from Sky connected to the Scart in on the DVDR (what make by the way) and both Scarts set to RGB.
    Wackojacko32
  7. start!
    start!
    Feb 26, 2005
    90
    I'll go and give it a try, dvdr is a Goodmans 301r
  8. mray
    mray
    Feb 16, 2004
    2,780
    83
    London
    +235
    I don't know if this applies to you, but some DVD Rec's show the picture as it will be recorded, when they are switched on. By this I mean if your recorder is set to record in long play, the picture you see on screen will look a bit blurry. If you set the Rec to XP, the picture you see via the source button will appear sharp. Does this make sense?
    I hope it helps. :)
  9. JayCee
    JayCee
    Jan 20, 2004
    23,988
    Lanarkshire
    +2,613
    No!
    I'm not aware of any DVDR's which do this, I doubt it very much.
    Can you tell me on what Make/Model you've seen this "Feature"?
  10. start!
    start!
    Feb 26, 2005
    90
    Wackojacko32, i've tried what you said but still no luck.
    On the dvdr it lets me choose video out and then select RGB but i can't see any way to change scart in to RGB.
    I've attached a picture from the instruction book showing how they say to connect it.I can't understand why they would show you to connect with scarts if the dvdr isn't compatible with them.
    mray: the picture is awful mate regardless of what quality setting its on,its difficult to make out people faces because its so bad.
  11. Rasczak
    Rasczak
    Apr 3, 2002
    23,104
    Warwick
    +3,732
    Philips DVD recorders have this option - the picture is encoded and displayed when the unit is on as opposed to being passed through (unless you select pass-through). It's one of several reasons why high-end users avoid Philips DVD recorders!
  12. JayCee
    JayCee
    Jan 20, 2004
    23,988
    Lanarkshire
    +2,613
    That must cause new users no end of problems........wondering why the picture is so poor and forgetting or even not aware they have this "Feature" turned on.
    Thanks for the info.
  13. Rasczak
    Rasczak
    Apr 3, 2002
    23,104
    Warwick
    +3,732
    ...it's also great fun when watching Sky when you start typing in a number on the handset to change channels - there is a delay as the picture is encoded by the machine.
  14. JayCee
    JayCee
    Jan 20, 2004
    23,988
    Lanarkshire
    +2,613
    "Philips, Simply Light Years Ahead", ahem I don't think so!! :smashin:
  15. Wackojacko32
    Wackojacko32
    Jan 6, 2005
    239
    Pinxton, Derbys
    Start!
    I don't have any specific knowledge of this model but if there is no option to select RGB input then it probably doesn't have the capability. Try the specifications part of the Manual, it might tell you there.
    Wackojacko32
  16. mray
    mray
    Feb 16, 2004
    2,780
    83
    London
    +235
    Philips.
    Mico.
    Lite-On.
    Tevion.
    All +R machines.
  17. start!
    start!
    Feb 26, 2005
    90
    Thanks for all your help but i've decided to take it back tomorrow and get a refund.I can't believe how the instructions tell you to connect a scart to the dvdr and then when i do the picture is crap.If its not got RGB input capability i don't know what the point is of showing you how to connect with scarts.There's no specs listed in the manual,anyway i'm sorry for moaning but i'm a little p****d off with it.
  18. JayCee
    JayCee
    Jan 20, 2004
    23,988
    Lanarkshire
    +2,613
    Better off putting the money towards a Panasonic or Toshiba.
  19. Wackojacko32
    Wackojacko32
    Jan 6, 2005
    239
    Pinxton, Derbys
    I agree with Jaycee, I have a Panasonic E65 and the PQ is excellent. Can pick these up for less than £200 now so why bother with anything else.
    Wackojacko32
  20. start!
    start!
    Feb 26, 2005
    90
    i want one that will play + and - though so as i can play dvds from friends who have + format.
    thanks
  21. Rasczak
    Rasczak
    Apr 3, 2002
    23,104
    Warwick
    +3,732
    Most DVD recorders, whether + or - recorders, will play the other format - although obviously they can't record to it. The Panasonic models are no different in this respect, i.e. they will play +R and +RW in most cases.
  22. start!
    start!
    Feb 26, 2005
    90
    I liked the look of the Panasonic DMR-E55EBS but i couldn't see were it said that it plays +R or +W. Can anyone confirm whether it does
