Poor Picture Quality
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by wiz, Mar 17, 2002.
  1. wiz
    wiz
    Aug 20, 2000
    4,111
    +3,134
    When ever I try the pictures look blocky; even when just connected to the
    computer prior to capture the view screen on the compter the picture is not
    very good infact it's poor. Panning simply produces squares on smooth edges.
    What am I doing wrong?
    AMD 1800+
    512 Mb Ram
    Videowave DV suite (Videowave 5)
    1394 card
    Panasonic DS27 camera
    Ossie
  2. Arthur.S
    Arthur.S
    Jeez, there's a million possibilities for this one. Are you capturing to a dedicated HDD? Is it DMA enabled? Is your firewire card sharing an IRQ with something? Is it in the slot next to your AGP? Your system is well up to spec for NLE, so there has to be a problem with the configuration of it.
