Poor Picture quality
T
toucan08
I am getting poor picture quality when watching and recording through my DVD player (panasonic DMR EH50) TV - LG 42PX3RV Plasma.
Can anyone help
Toucan08
Gavtech
Administrator
How is the DVDR connected to the TV ... and what is your signal quality like ?
For example, if you plug the aerial direct into the TV is your reception OK.
Is playback of Pre-recorded DVD's ok?
T
toucan08
its connected via scart leads.
When Arial direct to TV signal is fine
Gavtech
Administrator
A bit more information would help us to help you.
1 - Has it always been like this or have you just set it up and this is the problem you have ?
2 What sort of poor PQ are you suffering?
3 - Is the problem present on all channels
4 - If you have just set it up [ I am assuming the EH50 has an analogue tuner ] ensure that you are tuned to the correct transmitter. You may be tuned to a fringe transmitter.
5 - You did not report if pre-recorded DVD's playback OK ... which if OK would eliminate connection issues between the EH50 and TV.
T
toucan08
DVD Playback is exellent.
Playback with Sky through the DVD is slightly grainy, and analogue is worse still.
JoseD
Are you using a splitter to connect the aerial to the DVD recorder and TV or just passing through the signal ? If using a splitter it's normall.
Another VERY important thing to consider is the quality of the aerial cables. I used to have cable tv connected through a thin poor quality aerial cable. Custom building one with quality components made a noticeable difference. Cable companies want to cut on costs so they normally install crappy cables, this is widely known.
