Poor bass on Freeview
Discussion in 'Freeview & YouView' started by Canary_Jules, Sep 11, 2007.
  1. Canary_Jules
    Canary_Jules
    Jan 25, 2003
    3,499
    2
    Leicester, UK
    +1,157
    Hi I just upgraded my crappy old Goodmans pro logic system with a slightly less crappy Yamaha NSP-110 speaker set (well, it was only £36 on Ebay!), and have paired it with a decent Denon 1906 receiver I had spare. I've also just upgraded my freeview box from a Sagem ITD 64 to an Inverto IDL-7000 PVR which is connected to the Denon via optical.
    Okay, now to cut to the chase... While the sound is infinitely better than it was with the Goodmans it is distinctly lacking in bass even though I have the Denon sending all bass to the sub. The sub fires up nice for DVD playback but not freeview TV. Is this issue because freeview doesn't transmit a bass .1 signal or have is my set it all wrong somewhere? I'm using Dolby Pro Logic IIx setting on the Denon.
    Jules
  2. per-Sony-fied
    per-Sony-fied
    Jul 24, 2005
    2,305
    +100
    At present Freeview does not broadcast digital multi-channel surround sound.
    Most boxes will just output left & right stereo.
  3. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,280
    Manchester
    +763
    Surely it should work in Dolby ProLogic mode on films and the like - which have had the required embedded info for a decade.
    Chris Muriel, Manchester
  4. imigix
    imigix
    Jan 27, 2007
    277
    west yorkshire
    +10
    the posting stating no surround on freeview
    my set up nokia 9850t tuner yamaha dsp e800 prosseser cambridge 840 amp full spk set
    no problem getting full surround sound
  5. Canary_Jules
    Canary_Jules
    Jan 25, 2003
    3,499
    2
    Leicester, UK
    +1,157
    Hi guys, thanks for the responses. I've just checked out the Inverto forum and it seems this is a bug in the coax/optical output of the Inverto PVR that has never been fixed (even after 2 years!). Some people can't even get their receivers to recognise a digital signal, others who do find that the frequency range is emasculated. I've switched to analogue and just like magic the sub starts singing.
