Polyester Expandable Sleeving ?
Discussion in 'Home Cinema Building DIY' started by RobsterD, Feb 26, 2003.
  1. RobsterD
    RobsterD
    Dec 11, 2000
    891
    Southampton
    +12
    Anyone know of a supplier of expandable sleeving in small quantities in the UK,searches have only located bulk purchases,Take Five Audio can supply but are based in Canada
    Rob
  2. TooManyHobbies
    TooManyHobbies
    Nov 7, 2002
    1,386
    41
    South Yorkshire
    +13
  3. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    Rob, if you want some of that stuff from CPC I can add it to the bulk cable order form if you like - save you on postage...
  4. RobsterD
    RobsterD
    Dec 11, 2000
    891
    Southampton
    +12
    Cheers Rich,not sure on the diameter requirements yet,still waiting for the Belden 83802 to arrive,more than likely be CB0097066 3-8mm braid,will be running a 1.5/2.5mm earth round the cable any recommendations of sleeving size would be appreciated Darren7 if you're reading,will let you know as soon as I confirm cable diameter,will also require about 10 ferrite cores but again cant confirm internal diameters,when's the cut off date for your bulk order.
    Rob
  5. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    I've said next wednesday, but I'll be orderign from Rapid at some point soon too, who have some grey sleeving.
  6. potfish
    potfish
    Apr 8, 2003
    389
    Bristol
    +5
    Dragging up an old thread - anyone know any other suppliers of this expandable braided sleeving? CPC have discontinued theirs.
  7. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
  8. potfish
    potfish
    Apr 8, 2003
    389
    Bristol
    +5
    Could swear that wasn't there when I looked at the site a week or so ago. Or I'm just blind. Thanks.
  9. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    It's good stuff. I've used it on a few cables thanks to my fellow richard.:smashin:
  10. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    You're welcome, guv'nor.
    :D
    Did you finish the power supply, by the way?
  11. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    +59
    It's still getting there. Since I started my new job I've not had the time to do any more. I've got all the bits now though. Just need to build it. :D
    I'm starting to rearrange and redecorate my room this week so it will need doing for the end of that as my PC will be back in my room, and it needs to be quiet.
