Polk in-wall suppliers?
Discussion in 'Home Cinema Speakers' started by MarkHudds, Jun 22, 2004.
  1. MarkHudds
    MarkHudds
    Jun 12, 2002
    550
    +4
    Does anyone know anywhere that sells Polk in-wall speakers (specifically the RC55i or RC65i) apart from Hifibitz?
    Searched on Google but I can't find anywhere else and the Polk website lists one distributer in London as the only match for 'Dealers in the UK'.
  2. dragonfly
    dragonfly
    Aug 4, 2003
    141
    surbiton
    +3
    Markhurdd,
    The new Distributors for POLK AUDIO Speakers in UK are Teklink Distributors Ltd 68 St.John Street London ECIM4DT TEL..02077025277 OR
    info@teklinkdistribution.com :thumbsup:
  3. ShinObiWAN
    ShinObiWAN
    Oct 2, 2003
    749
    16
    Derbyshire
  4. MarkHudds
    MarkHudds
    Jun 12, 2002
    550
    +4
    Thanks guys
    I've ordered from Hifibitz in the end ... they reckon it's next day delivery to them and then next day to me - so that's not bad!
  5. Lennyz
    Lennyz
    Jul 27, 2002
    339
    Cheshire
    +13
    I would be interested to know what you think of the sound and quality of these when you get sorted Mark. I have wondered about these in walls myself.
    Lennyz
  6. MarkHudds
    MarkHudds
    Jun 12, 2002
    550
    +4
    Lennyz - I got 2 pairs of the RC55i model for rear and back surround duties in my 7.1 set up (mains - MA silver 9i, centre - MA silver 12i, sub - Velodyne CHT-15). I had 2 pairs of the MA silver FXi surrounds, however one of the pairs was in an inconvenient location - sticking out into a stair case.
    So have I sacrificed timbre matching for the cosmetic appeal of in-walls? I reckon not ... I would say its more important to match your front sound-stage than the complete set up. The Polks work very well with my MA, if anything they're slightly less harsh than the FXi's.
    Aimable tweeters is a big bonus too as personally I prefer a more direct surround sound rather than diffused.
    Installation would be a doddle if you have the required 7cm depth in your walls. I had about 3cm, due to dry-lining (plasterboard dabbed directly to concrete blocks) so I had to get my SDS drill out and chisel out the extra 4cm. Hard (and messy) work but worth it for the end result! The locking cams work brilliantly though - best fixing I've seen for in-walls.
    I'd recommend them and if you've got a decent sub and all your speakers set to 'small' on your amp, then I wouldn't go for anything bigger than the RC55i's.
    Let me know if there's anything else you'd like to know about them.
    Mark.
  7. Lennyz
    Lennyz
    Jul 27, 2002
    339
    Cheshire
    +13
    Thanks Mark,
    I am still considering the in walls. I presently have a complete M&K K series setup and I am intrigued by the in wall option for the looks side of it.
    I appreciate your reply and I may well ask you some more about them. I have just moved house and am currently doing the lounge to my own spec so I have a few decisions to make.
    Ta
    :thumbsup:
