Polarity & Mission 771e & Denon AVR1803
Discussion in 'AV Receivers & Amplifiers' started by Dimmy, Mar 9, 2003.
Tags:
  1. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    For some bizzare reason, my Mission 771e front speakers are out of phase whenever my speaker cable is connected 'in phase' with my Denon AVR1803!
    If I reverse the polarity of the speaker cables, so that they're out of phase (theoretically anyway), then they're all of a sudden back in phase!
    Is this something wrong with my Amp or Speakers?
  2. EvilMudge
    EvilMudge
    Sounds like another (admittedly very rare) problem with Mission's quality control. Don't worry about it (unless the tweeter is out of phase with the woofer in which case you should have grounds for a return.)
