Polariser filter
Discussion in 'Photography Forums' started by dts197, Aug 2, 2012.
  1. dts197
    dts197
    Aug 12, 2006
    4,913
    +662
    Not sure if that should be with an 's' or a 'z'!
    Anyway, after a bit of reading that one would improve the colour of outdoor pictures I'm looking into getting one. I'm just not sure what size I'm supposed to get. It would be for my Canon 15-85mm lens. Hope I'm not asking a daft question!
    I'm also not sure how much to spend to get a decent one? Can anyone advise on what I should be looking at? I gather that Hoya ones are good to get and looked at this one on Amazon:
    Hama Circular Polarizer Filter 52mm: Amazon.co.uk: Electronics
  2. Dancook
    Dancook
    Feb 15, 2007
    15,278
    +6,021
  3. dts197
    dts197
    Aug 12, 2006
    4,913
    +662
    Thanks for the links, I'll have a good read when I finish work.
  4. sep8001
    sep8001
    May 2, 2008
    2,681
    103
    +284
  5. dts197
    dts197
    Aug 12, 2006
    4,913
    +662
    Yes, that's the one. Just a shame all 3 lenses I have need different size filters!
  6. vala
    vala
    Apr 4, 2007
    208
    +6
    An option then would be to get all your filters at the largest size needed. Then buy step up rings to enable you to fit them on the lens which have a smaller diameter filter thread.
  7. dts197
    dts197
    Aug 12, 2006
    4,913
    +662
    Thanks for that, didn't know you could do that.
  8. Goody
    Goody
    Dec 22, 2005
    425
    Plymouth
    +74
    It should be with an 's', so you got it correct. Hope this helps. :D
  9. dts197
    dts197
    Aug 12, 2006
    4,913
    +662
    Haha, thanks! I wasn't quite sure as when I started typing on Google/Amazon, both showed up. I'm guessing Americans spell it with a 'z'!
  10. Goody
    Goody
    Dec 22, 2005
    425
    Plymouth
    +74
    Yes.That's the way I generally look at things. Anyway, I have a Hoya Pro1 filter and it does the job.
  11. dave_bass5
    dave_bass5
    Jul 6, 2004
    6,741
    London, centre of the universe
    +637
    Yep, thats the one i have for my 15-85IS.
    I got it because i read a lot about how good these things are with sky's/foliage etc, and im sure they are but ive hardly used mine since i got it.
    For a start its quite fiddly to use with the hood on, although not impossible, and when shooting at the wider end you dont always get a even effect on the sky, although zooming in a bit helps.
    I think they are worth having if you do need them, but not a necessity for general outdoor pics, as the sun needs to be at a certain angle to the camera for the filter to make any difference, and in my experience a lot of the item it isn't in the right place. Its good for getting rid of reflection's though.
  12. dts197
    dts197
    Aug 12, 2006
    4,913
    +662
    Not so sure if I should get one now! Thanks for your views on it, dave_bass5
  13. dave_bass5
    dave_bass5
    Jul 6, 2004
    6,741
    +637
    No problem.
    My views are only based on my usage, and living in town i tend not to do many landscape shots, nor do i have a garden so i tend not to shoot foliage much. I have noticed that the filter really does make a nice difference when i can use it, its just that i dont find i can a lot of the time.
    I do have one for my 40mm pancake lens as well and i find it works better on that, easier to use as i dont use a hood on that, and of course its not really a wide lens so the result is more even.
    I know it all sounds a bit contradictory, im glad i have them, and will never sell them, but cant see me using them much.
    I'd say go for it if you can afford it. They do something that cant really be done in PP, unlike a lot of other filters, just be aware that it wont be an everyday filter.
  14. dts197
    dts197
    Aug 12, 2006
    4,913
    +662
    I know what you mean, better to have something and not always need it than vice versa. And it's not too expensive.
  15. Geege
    Geege
    Jun 27, 2006
    2,974
    +430
    Have you considered in investing in a square filter / slot in system. You can also buy drop in circular polariser filters for these systems too. Such as Cokin X-pro, and Lee filters etc...
    This is more versatile especially if you have a number of lenses with different filter screw sizes and reduces the risk of vignetting on wide angle lenses.
  16. dts197
    dts197
    Aug 12, 2006
    4,913
    +662
    I'd not even heard of a square filter / slot in system until now. But thanks, I'll do some research before deciding what to get.
  17. Geege
    Geege
    Jun 27, 2006
    2,974
    +430
