POI and Speed Camera
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by barrybarryr, Mar 23, 2006.
  1. barrybarryr
    barrybarryr
    Sep 26, 2004
    735
    +19
    I'm thinking of buying a sat nav system, probably the Garmin i3, and want to know how do I download the POI and Speed Camera datatbase to the unit?
    Is there a step by step guide anywhere or do I just drag and drop to a memory card?
    Also what type of information is in the POI database? Does it have things like supermarkets, shops etc? Or just things like landmarks?
    Can someone help?
  2. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
  3. kvee
    kvee
    May 11, 2005
    89
    The Garmin has a useful software tool - the POI loader.
    Easy to use. Plug Garmin into PC, lauch POI loader, open directory holding POI file and POI loader does all the loading onto the Garmin. Job done.
  4. barrybarryr
    barrybarryr
    Sep 26, 2004
    735
    +19
    Thanks,
    I've looked on the pocket gps website and it had loads of files for example Tesco, Safeway, Walks in Surrey etc? Are these the POI files you talk about?
    Can I pick which files I want to load? How many can I load (does this depend upon the size of the memory card)?
    I want to by one but am still confused!
  5. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
    The POIs are overlays for your maps. I downloaded the last free safety camera file from there. My PDA shows cameras, cash points & petrol stations- I turned all the other off.
    Some POI may already be loaded in your maps. The safety camera database costs a £2 a month subscription now :mad:
  6. the porter
    the porter
    Dec 15, 2004
    5,848
    lancs
    +1,593
    you can put 30000 pois and all the speed cam database and the i3 will hold them all no probs!
  7. barrybarryr
    barrybarryr
    Sep 26, 2004
    735
    +19
    What I'm trying to work out is if this is where I download the POI files.
    I have looked at this http://www.pocketgps.co.uk/tomtompoi.php but all I can see is tom tom mentioned not a Garmin, are these the files I use?
  8. the porter
    the porter
    Dec 15, 2004
    5,848
    lancs
    +1,593
    no somewhere on the site there is a thread which tells you how and where to put everything on the i3 ill see if i can find it again hang on!!
  9. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
    I don't know anything about Garmin but there is a forum on the PDA site, I'm sure there'll be a Garmin section.
  10. the porter
    the porter
    Dec 15, 2004
    5,848
    lancs
    +1,593
