PoE Doorbell Camera?
The Commander
I am having the house rewired and networked so what are my best options for both ease of use and reliability - I am having full copper cat 6 cable installed throughout the house and was wondering should I also get a cat 6 cable terminating on my front door to setup a PoE doorbell camera?
Or should I just wire up a low voltage cable and go with a wifi doorbell camera but with wired power connection.
Seb Briggs
We use Doorbird mainly on our installs , they can be wired or wireless But always choose wired if you can
chazman88
Ring Doorbell Elite if you want to stick to that type of doorbell.
D
Deleted member 24354
Yeah good luck chasing the back box in for that doorbell. They are a pig to install.
mindforge
I got the Hik vision flush install PoE intercom, so much better than the Ring I had before and integrated with the Hik vision cctv cameras too.
