pocketdab1000 + creative travelsound400 problem
Discussion in 'Music Streamers' started by spk, Aug 4, 2006.
  1. spk
    spk
    Jan 24, 2005
    29
    hi, i've a problem thats doing ma nut in !!!, i got a set of the 400's to allow the pocketdab to be used as a portable dab while camping. sounds easy enough so far....
    now, every time i turn the power on the 400's the dab looses all signal's on every station :suicide: !!!!!
    any clue as to why this will happen or a work around ??
    thanks
    spk
  2. ProfessorYaffle
    ProfessorYaffle
    Feb 6, 2006
    553
    28
    +85
    Alas, tney're probably powered speakers and, as the radio uses its headphone (or speaker if connected) cable for an antenna, you're doomed to failure. It's down to that damn electricity, I believe... But all is not lost...
    A pair of passive speakers, such as these, should do - I use them with my Bush PSDAB2004 with no problems (and tney sound surprisingly good for a fiver!). No batteries required, obviously - another bonus.
    Hope this helps!
