Pocket PC good for remote use?
Discussion in 'Home Cinema Control & Remote Controls' started by russraff, Oct 25, 2004.
  1. russraff
    russraff
    Aug 1, 2000
    2,415
    Newcastle
    +64
    I was thinking about getting a Dell Axim X3 or Compaq or similar and using it as a remote by getting some third party software. Is this a good way of doing things, or is this approach more trouble than it's worth? It seems like the colour Prontos are tragically overpriced in comparison. If it is worth doing, are the models I am thinking of using good ones, or are there different models I should be looking at?
    Russell
  2. Mr. Wilby
    Mr. Wilby
    Dec 15, 2002
    641
    +16
    Worth doing a search. There's one very long thread on this forum started by Messiah about using pocket pc as a remote.
  3. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
    I use an iPAQ 2210 running PDAWIN (which uses Pronto CCFs) as a universal remote and it works just fine. It's pretty directional and hasn't got a huge range but, as all my gear is directly in front of where I sit and abput 9ft away, it's never been a problem.
    HTH
    John
  4. HMHB
    HMHB
    Nov 11, 2001
    26,722
    Nottinghamshire
    +5,489
    I use Nevo on my Ipaq 2200 and it works fine - it comes as part of the package with the 2200. One thing you have to check is that it has a good enough IR, I think it has to be "consumer grade" or something like that. Not every PDA can do this.
  5. russraff
    russraff
    Aug 1, 2000
    2,415
    Newcastle
    +64
    I was thinking of the 2210, actually. So, this doesn't have a consumer IR? I have just looked on the net and there doesn't seem to be a list anywhere, even on Remote Central, that tells you which PDA's have Comsumer IR and which don't. I have actually checked Dell and the X3 standard doesn't seem to be available and the X30 range doesn't list consumer IR as a fearture. So... I am a bit lost, here. Anyone shed some light as to which PDA's would work well, other than the 2210 (I may need a longer range).
    Russell
  6. HMHB
    HMHB
    Nov 11, 2001
    26,722
    Nottinghamshire
    +5,489
    If you're talking about the Ipaq 2210, that is the American version of the 2200 and they do have the consumer grade IR.
  7. russraff
    russraff
    Aug 1, 2000
    2,415
    Newcastle
    +64
    Are you sure? I looked on Kelkoo (as a first stab at prices) and they say PC World have this model in stock over here (link here
    If this has Consumer IR, I'm getting one. Simple as that!
    Russell
  8. shoehorn
    shoehorn
    Jul 2, 2003
    1,610
    The Garden of England
    +32
    You could always try one of these, I don't have one myself, but if you have a PDA without consumser IR, or short range, it could be just the thing.
    If I can get it past the Mrs I'll get one for my 4150....
  9. russraff
    russraff
    Aug 1, 2000
    2,415
    Newcastle
    +64
    Hmm, so, all is not lost if the range is too weak. Looks good. I was going to get PDAwin as the software, but will have to change my mind methinks.
    Russell
