Poblems i have had since rollup2
JonLeach
Hi All
thought i woud elghten a few folk as to what my system had done sine rollup2.
i had installed it as i really wanted the radio channels.(worked great).......
....this is what doesn't work.
1. Sonicencoding straight to dvd video, file incompatible error message.
2. Music will not record to cd either same fault as above
3. Browsing "My Music" and "My video" slower than ever. Make a cup of tea time.
4. Dcut fails to work after upgrade
5. S3 shutdownfails to work. Worked before Rollup2
After rolling back to a Restore point everything is back up and running. Reloaded guide works ok.
Message to self
"buy a new keyboard as the BTC one don't type very ood"
Anyoe ele wih some more problems
mark.carline
JonLeach said:
Hi All
Message to self
I just wondered what kind of issues you where having with S3 shutdown ?
JonLeach
Post Rollup2,
Wil not turn fans off, Reg hack in place
Will not resume PC reboots after blue screen
Pre Rollup
everythig was fine
"this damn keyboad"
Jon
MattTheBeanster
John, is your keyboard a BTC 9019? does it miss letters? does it need reconnecting often. Is so you too could have a dodgy piece of ****. ;)
Had the same problem with mine, spilt brandy in it, got a new one (same model again, glutton i know) and lo and behold 3 weeks no disconnects and not a single letter missed apart from my dreadful spurling.
JonLeach
its a 9116, it seems to miss letters that are close to ech other on the keyboard. might get some new batteries.
Jon
cant tell you how many times i had o type battries. :(
Sandman
I have this exact problem...
Worked fine before update. I am going to try to reinstall sonicencoders to see if that fixes the problem.
jimbob19
I have the same issue - cant burn music cd's either , have reinstalled sonicencoders - still no joy :(
JonLeach
removing rollup 2 fixes it. i think its a incompatilbity with
codec/dvd writer
i'm using
Power DVD from cole website and lg dvd rewriter.
rather have a working dvd writer than radio!
functionality of My music and my videos comes back too.
jon
Sandman
I am also using Power DVD. Is this the problem? Anyone else with this problem using Power DVD?
JonLeach
Looks like Power DVD is the culprit. i have just installed a trial version of windvd 7.0 after removing the power dvd codec and creating dvds now works fine.
Now i need to test audio functionality, tv fastforward with spdif connection adn DD and dts passthru
Jon
