Pnansonic TX-32DT2/Pioneer DV-350
Simon77
Have been using a multiregion Pioneer 626 for a few years now linked up to a Panasonic TX-32DT2 via an RGB scart lead. No problems.
Have just bought a multiregion Pioneer DV-350 and playing PAL discs (region 2 and 4), again, there is no problem. The problem arises when I play an NTSC disc (region 0 or 1) via the RGB scart. The picture is distorted, with lines flickering across the screen. Tried different scart leads and all that, retuning etc
Is anyone aware of an incompatibility between the DV-350 and the TX-32DT2? Is there a solution to it?
Simon
kevb
Have a search for a thread called "Flicking Hell" posted by Juboy. I posted a link to a document that gets you into your Pani TV's set-up menu to adjust some settings. It help cure Juboys problem so give it a try.
It Helps most people get a better picture. Let us know how you get on Please.
