PN43F3400 vs UN39F5000
Discussion in 'What Is The Best TV For You?' started by amandarg, Feb 10, 2014.
  1. amandarg
    amandarg
    Feb 10, 2014
    I'm going to be buying my first flat screen and I have narrowed the field down to these two. I live in a basement apartment so glare from the sun will not be an issue. I also will not be hanging the television so depth of the screen is not an issue. The price of the two TV's is only a $20 difference. I'm just going to be using this television to watch TV (shows and sports) and movies. I have a blue ray player with wifi so a smart TV is also not important.
    Does one of these options seem like a much better choice over the other? From just reading reviews I cannot find much of a difference other than the fact that plasma allows wider viewing angles. Am I wrong?
    Thank you,
    Amanda
