Pmc
Discussion in 'Home Cinema Speakers' started by Howard Sorsby, Mar 29, 2001.
  1. Howard Sorsby
    Howard Sorsby
    Nov 6, 2000
    2
    It's been suggested that I consider PMC loudspeakers (model FB1) as a good compromise for a Home Cinema L+R pair and also as hi-fi speakers. It's a make I've not encountered before. Does anyone have any experience of them?
  2. General Skanky
    General Skanky
    Jul 28, 2000
    4,247
    71
    +43
    They always seem to get very good, solid reviews whenever tested in the mags.
    Their pro pedigree at the very least helps to show you'd be buying quality stuff.
    I can only suggest you let your ears decide, but I'd have them high on my priority list these days!!
    Douch!!......Wot's da madder, da CIA got you pushing too many penzils?
    Work: www.hughes-tv.co.uk
  3. Guest
    Oh Yes, buy with ABSOLUTE confidence my friend!!!
    Regards
    SteveEX
  4. Matt F
    Matt F
    Jul 18, 2000
    900
    Chester, UK
    +4
    Fantastic speakers - their bass is excellent and drops so low that you won't need to worry about getting a subwoofer. Check out the review of them at www.hifichoice.co.uk.
  5. adamtandy
    adamtandy
    Apr 6, 2001
    12
    London
    I've spent a lot of time working with PMCs, both big and small, and I have mixed feelings about them.
    They all have enormous sound handling capability and response, but I find them a bit over-lively for a lot of normal listening. They'll show up every flaw in a source, so unless you can guarantee you will only ever be listening to top-notch sound, you may end up hating them.
    My advice: audition them carefully with a variety of material.
  6. minimivic
    minimivic
    Mar 28, 2001
    230
    Shaftesbury, Dorset
    +16
    Definitly have a listen.
    Preferably at Home, I didnt get on with them very well. But heard them at someone's house and thought they were OK.
    A bit slack ( wooly ) in the bass region.
    Otherwise I agree with Adam.
    Sharky
