PMC TB2S+ advice please
Discussion in 'Home Cinema Speakers' started by JimBob1971, Feb 11, 2009.
  1. JimBob1971
    JimBob1971
    Jan 12, 2004
    2,532
    +744
    Am I right in thinking these are exactly the same soundwise as the TB2+ speaker, and that the only difference is they are not finished in wood?
    I'm guessing these would be superior speakers to the DB1+?
    Finally, what is a decent price for a second hand set? (With and without stands)
    Thanks for your help!
    James
  2. CallMeSteve
    CallMeSteve
    Feb 13, 2008
    3,625
    83
    +152
    Yes they are the same apart from the finish. I would imagine they are a step up from the DB1+'s but not sure how much as I've never heard them. As for price, I sold mine for £350 with the stands which was quite a bargain :D.
  3. Member 96948
    Member 96948
    Nov 18, 2005
    10,238
    The Fen Edge
    +2,253
    Superior? Yes and no. Yes, they're more dynamic a touch easier to drive and have slightly deeper bass, but the DB1s are a bit easier to accomodate close to a wall and handle female vocal with a bit less 'chestiness'.
    For most people, it's still going to be yes.
    Russell
  4. JimBob1971
    JimBob1971
    Jan 12, 2004
    2,532
    +744
    TB2S+ versions for £350 plus stands??? Wow Stevie. Is that really what they go for, or is that a very good deal
    Russ, I'm also considering the GB1 and GB1i. Do you have any experience with these compared the to TB2+?
    Thanks,
    J
  5. PSM1
    PSM1
    Dec 20, 2008
    26,283
    +5,440
    I listened to some TB1s when I was demoing speakers a year or so ago. Was very impressed with the sound from them. In the end I went for GBs at the front and DBs for the rears. The reason I did not go for the TBs is I wanted floor standers at the front and to match the sound of the TBs at the rear I would have needed FBs at the front (did not have the budget for that kind of upgrade). You should definately get some good deals on the + models now that the i model is out.
