PMC GB1's against a wall
Discussion in 'Home Cinema Speakers' started by vishnu, Apr 24, 2007.
  1. vishnu
    vishnu
    Jul 13, 2003
    489
    Milton Keynes
    +68
    I currently have PMC ob1's as the main front speakers and a cb6.
    I am thinking about upgrading my rear speakers to GB1's.
    The trouble is i would have to have them pretty much touching the side wall.
    As they are quite bassy speakers, can you see this being a problem or would they be ok as they would only be used for surround affects?
    If so i would look at the wafers. I would prefer the GB1's though not just for the sound quality but the look would match better as well.
    Any comments would be appriciated.
    Richard
  2. chewie13
    chewie13
    Dec 12, 2002
    78
    Edinburgh
    Richard,
    I have GB1's as my front left and right speakers. I have them about 6" from the screen wall and they sound great. I think, although others may correct me, that because they are front ported it makes it easier to get them closer to the wall.
    B
  3. Member 96948
    Member 96948
    Nov 18, 2005
    10,238
    The Fen Edge
    +2,253
    Mine sounded too overbearing and thick until I had them at least 30cm out from the wall. I do suspect this would be less of an issue as surrounds.
    Why not DB1s? Better still, why not a pair of M&K column surrounds?
    Russell
  4. vishnu
    vishnu
    Jul 13, 2003
    489
    Milton Keynes
    +68
    Ideally would like Gb1's as they would be an ideal match for tonal balance and looks for the rest of my speakers.
    If they would be too bassy i would look at the DB1's on stands or the wafers.
    Just looked at the M&K you sugested, they look good and a nice solution, but after having dipoles as i have now i prefer the sound i had before with direct firing rear speakers, also they seem to only come in black and I prefer a wood finish.
    How do the Tripole M&K sound with your PMC's?
    Richard
  5. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,111
    notts.
    +76
    Having owned dipole speakers theres no comparison with the m&k column surrounds if you can get to hear them iam pretty sure you would buy them, Imo they are one of the best surround speakers you can get.
    Also tonal matching on the rears isnt as important quite a few forum members run the columns with other brands of speakers.
  6. Smurfin
    Smurfin
    Aug 13, 2002
    21,462
    +4,393
    I you want monopoles then take a look at the Wafer2s....basically a (not quite) flat panel version of the TB2+.
