Plz is there any DVD hacks for SONY DVP S725D
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by DanAshmoreUK, Apr 9, 2003.
  1. DanAshmoreUK
    DanAshmoreUK
    Hi huys i was just wondering if there are any hacks for this DVD player because this is my fave DVD at the moment and sadly it doesnt even play CD-R's?:(
    Im hoping there are codes to make it play cd-r's, disable macrovision or to make it multiregional
    and id be dreaming to say progressive scan:)
    thx guys
    Ashmore
  2. nathan_silly
    nathan_silly
    To get CD-R replay you need dual lasers.
    No chance of a remote hack to get it multi-region/macrovision, progressive scan requires new board/deinterlacer. Which yours hasn't got
    Sony's require a mod chip.
    If you want R1, I would buy a imported 110V machine, leave as R1, and leave yours as R2.
    Sony mods are a bit dodgy (I've got a 110V R1 Sony as well, I will not mod it)
  3. mjn
    mjn
    May 24, 2001
    22,246
    Herts, England
    +10,093
    the 725 has dual lasers, and it'll read certain brands of CDR.
    but for all other features you'll need a hardware mod chip.
    PS ?? not a chance!
  4. nunew33
    nunew33
    Jun 5, 2002
    1,736
    41
    Lytham St Annes, where people are put out to grass
    I have found that Vivitar CD Rs work ok.
    They are available from www.pczoo.co.uk. Cheap but postage kills the price!!!! Its £5.50 delivery!!!
    But Ive bought these and tested them and they work on the Sony
    Its worth noting though that a bloke oposite me bought a spindle of 50 vivitars from Dixons and they didnt work when i tested them. Not sure how you tell which is which.
    What I do know is that its the coating on the CD that makes a difference and that Vivitar use a patented compound!!!
    If you do some googling on the subject you will find a wealth of information why the vivitars work with 1st generation DVD players and others dont.
    Edit: just noted that pczoo are doing 100 vivistars 650M in jewel case inc vat and postage for £30.75. This seems like a good deal.
  5. Mike Dando
    Mike Dando
    It should play CD-RW's. Mine does.
  6. nunew33
    nunew33
    Jun 5, 2002
    1,736
    41
    CD-Rs are cheaper!!!!! and they do work, .......honest!
