Plz HELP re HDTV
Discussion in 'TVs' started by tolmie, Aug 29, 2005.
  1. tolmie
    tolmie
    Dec 10, 2004
    1,011
    Glasgow
    +56
    I have A panasonic PD50, superb TV, it has a component Connection, im getting at xbox 360 which you can get a HD component lead, does that give me a true HD connection, i thought HDMI was the only connection for HD but people are telling me the hd component connection will do the business, if so does it give me 1080i or less, im a bit confused with all this.
    Cheers in advance.
  2. locky79
    locky79
    Aug 27, 2004
    530
    +8
    well to get HD you can either go via component, DVI-D and HDMI but dont worry if your gonna go for the £279.99 xbox 360 pack then you will get the cables you need :) whether they are any good is another question :rotfl:
  3. tolmie
    tolmie
    Dec 10, 2004
    1,011
    Glasgow
    +56
    so is component cables HD ready, i didnt realize that, i thot you had to have a HDMI connection for HDTV,very confusing. Your comments plz.
  4. Br41ns
    Br41ns
    Apr 5, 2005
    424
    Glasgow
    +31
    :hiya:
    For a TV to be HD ready it must have an hdmi or dvi input which is hdcp compliant, however you can send an analogue HD signal up a component lead at 720p or 1080i and assuming your tv is HD then no probs, even sky are rumoured to have component on their 1st gen HD boxes.
  5. tolmie
    tolmie
    Dec 10, 2004
    1,011
    Glasgow
    +56
    I only have component connections on my TV, so is that good enough
  6. av addict
    av addict
    Jan 27, 2005
    2,152
    +161
    if its hd ready and accept 720p or 1080i
  7. Rimmer
    Rimmer
    Don't know specifically about the PD50, but there are hardly any CRT TVs in the UK that will accept an HD signal.
  8. chedmaster
    chedmaster
    Jan 29, 2005
    2,654
    68
    +28
    it def wont show the image in HD and I don't think it accepts 720p/1080i. I think only JVC tv's accept this (and the samsung slim fit HD if thats for sale yet).
    therefore there is likely to be little advantage for you anyway, but still get the component cables so you can have 576p (does PD50 even accept progressive?)
  9. tolmie
    tolmie
    Dec 10, 2004
    1,011
    Glasgow
    +56
    Well from what im getting told from the xbox site is this, you get a hd component cable and that connect from hd connection on xbox straight into component on TV, this cable comes free with xbox and works on any tv with component,
  10. chedmaster
    chedmaster
    Jan 29, 2005
    2,654
    68
    +28
    yes but your tv is not an HDTV. it will work but you will have to select a non-HD resolution on the 360, eg 480p or 576p (or 480i/576i).
  11. tolmie
    tolmie
    Dec 10, 2004
    1,011
    Glasgow
    +56
    So whats the point in bringing that cable out then, if you go onto gameplay they are selling it aswell and say it will work for HDTV, 1080i and so on. I didnt think it would work myself but there saying it does.
  12. tolmie
    tolmie
    Dec 10, 2004
    1,011
    Glasgow
    +56
  13. chedmaster
    chedmaster
    Jan 29, 2005
    2,654
    68
    +28
    your not listening.
    your tv has 576 lines.
    hdtvs have 720 lines or above, and therefore accept 720p and 1080i
    your tv doesnt support progressive scan
    therefore you are limited to 480i and 576i
    you may see an improvement in quality over standard RGB scart with the lead, but it will not be HDTV.
    If you had an HDTV (eg panasonic pv500 plasma, pioneer 435xde plasma), you would get hdtv with thaa lead.
  14. tolmie
    tolmie
    Dec 10, 2004
    1,011
    Glasgow
    +56
    I understand how the technology works, so what is th point in this lead, why does it say it will show 1080I etc when component cant or cant it but only on a HDTV which i thot required hdmi connection or dvi.
  15. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    The point is the the Xbox360 will pump games out at HD resolutions via a component connection. This same cable will also be suitable for people with displays that have component but will only display PAL/NTSC progressive or bog standard PAL.
    HDMI and it's HDCP protection is only going to be needed for playing back HD movies which at this point the Xbox360 will not do unlike the PS3.
  16. Eiji
    Eiji
    Feb 16, 2005
    1,382
    48
    +43
    Only one consumer grade HDTV CRT unfortunately in the UK, the Samsung WS32Z308P.
    tolmie, your TV supports only 480i (Interlaced) and 480p (Progressive) so with component cables and a Xbox 360, you won't be getting a HD picture on your TV, only ED (enhanced definition).
