PLVZ1 Digital Zoom help
Discussion in 'Projectors, Screens & Video Processors' started by Sarah T, Jan 8, 2005.
  1. Sarah T
    Sarah T
    Can anyone tell me how to adjust the digital zoom on the Sanyo PLVz1?
    I can get the option up on the screen but it's greyed out.
    EDIT Also,
    I use a video cable from the projector to the Sky box but would like a better quality picture.
    I have tried using S-Video cable,Scart - VGA and RCA X 3 but none of these cables produce a picture.
    Any ideas ?
  2. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,665
    Bristol.
    +309
    consider an RGB to component converter from somewhere like
    www.keene.co.uk
    Cap :)
  3. oneline
    oneline
    Nov 3, 2002
    33
    St Helens
    The only time you cannot use zoom is when using some component settings.
    I use a scart to vga cable supplied by Keene
    http://www.keene.co.uk/pages/cat/11lea/11F.html
    they can make it to a custom length if required.
    When using above cable select computer input/RGB(Scart) and make sure skybox is set to RGB.
  4. Sarah T
    Sarah T
    I've tried that now and still no joy. If anyone has any other ideas I'd be grateful.
  5. stevelup
    stevelup
    Aug 13, 2002
    6,518
    Swindon
    +1,091
    SCART to VGA definitely works perfectly.
    I know literally dozens of people who had/have their Z1's configured in this way.
    You need to double check a few things:-
    1) Is RGB definitely selected on the SKY box
    2) Are you definitely plugged into the TV socket and not the VCR socket
    3) Is your RGB SCART cable correctly wired?
    - R->R
    - G->G
    - B->B
    - Composite->H-Sync
    Unless your Sky box is either a Sky+ box or one of the few Grundig boxes with an S-video output, you will not be able to use S-Video without buying a converter.
    Steve
