PLV30 optimum set-up
Discussion in 'Projectors, Screens & Video Processors' started by Johnty, Sep 22, 2001.
  1. Johnty
    Johnty
    I have been following threads on the PLV30 and hoping to get a demo soon.I note that it is essential to set up the projector proprerly for optimum performance.What does this entail?<br />What would be the procedure for the PLV30?<br />Knowing that may help me understand if demo is set accordingly and that I am seeing it function at its best.
  2. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    In a demo you probably have to take the word of those in the shop, unless they let you take your copy of AVIA with you to calibrate!
    Ad
  3. Johnty
    Johnty
    Hi Ad,
    tks yr comment
    As you have the Plv30 what specific set up have you carried out to ensure optimum prformance/
    Is there any specific tweaks necessary?
  4. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    all i have done is set up with all the tests that are associated with the avia disc. To be honest, im certain the picture can be bettered, if i had the opportunity, I would get hold of gordon from these forums to come and set it up, if you want the best, he is the guy to do it!
    Ad
  5. Johnty
    Johnty
    Ad,
    You mentioned this AVIA disk for set up purposes.
    I`ve seen this mentioned before.<br />Where can I obtain one for PAL system?<br />rgds
    John
  6. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    ahha! A pal avia disc.....that question i cannot answer, whether one exists i dont know! Since i use region one dvds almos exclusively, i dont really care about pal! You can get the regular ntsc disc at <a href="http://www.movietyme.com" target="_blank">www.movietyme.com</a> if you search under misc.
    Ad
  7. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,782
    Cheshire
    +109
    AFAIK, there are no Pal equivalents to the AVIA and Video Essentials discs yet.
    Using AVIA teaches you what a correctly calibrated NTSC picture should look like (given the limitations of your particular set-up). Once you know what to look for you can then apply the same knowledge to PAL, using regular films as a "test signal".
    A few quick tips:
    First, make sure that the shops' DVD player is set to 16:9 - you'd be surprised how often they get this wrong. Check the projector is set to 16:9
    Setting black level: Play a 2.35:1 anamorphic film. Increase the brightness until you see grey/black bars appear above and below the picture. These bars should be slightly lighter than normal black background. Now reduce brightness until bars match the background.
    Setting contrast: Use a film like Shakespear in Love or Saving Private Ryan. Pick a scene with a shot of sky or lots of light whites and creams.
    With the contrast set too high, details in the lightest areas of the picture disappear, we call this "bleaching out". It's very similar to over exposeure in a camera.
    Reduce contrast to see the detail return. Reduce further and the picture starts to lose impact and look a little flat.
    The correct setting is just before fine detail bleaches out.
    Good luck
  8. Johnty
    Johnty
    Just like to thank Ad and Chris for useful info.
    Will order copy of AVIA disk and take along to demo.<br />rgds John
