plv30 and proggressive scan
Discussion in 'Projectors, Screens & Video Processors' started by jason t, Jun 26, 2001.
  1. jason t
    jason t
    Mar 4, 2001
    1,709
    48
    kent
    +38
    hi can somebody please tell me if the plv30 only supports proggressive scan through the component inputs or will it work through the 15 pin d plug fed via htpc
    thanks
    jason
  2. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,783
    Cheshire
    +109
    It will work via both connections.
    Regards
