richardglazer
Stopped working after one day. Not sure what the issue is...
Appears to turn on with a "very" dim light but cannot get anything to display nor does any remote or menu options work. Appears to be "hung" and non responsive. Only way to turn off is via the switch. After a few minutes it can be turned on again via the remote or set top switch but the same condition exists... EXTREMELY FRUSTRATED and would really consider returning at this point. I had reservations about buying anything that is Sanyo or has the Fischer name on it. It appears I should have not compromisted quality to save a few bucks... Not sure how the return will go as I have already sent in my rebate. Anyone have any ideas or thoughts as to what the issue may be? How about the rebate debacle? Will I still be able to return seeing I cut the code off the box.
