I
irishstu
Hi, I got sky HD on Monday and after realising 720p will not work with progressive through the z2 (50/60hz) I tried Hdmi. I am getting a black screen until I actually put the box into standby and then turn on again, no big deal but... it is only working on 576p, perfect picture. On 720p or 1080i you can see a picture but it is covered in horizontal interference over the entire screen I plan to take a couple of photos tonight to see if anyone can tell me what this is.
I have a gold plated hdmi to dvi adapter then (cable is installed 2 years) it is either a 10m or 15m (can`t remember) good dvi cable.
I Initally thought it was the length of the cable causing problems and didn`t realise the 576p was working until last night.
I upgraded the firmware on the projector to 106 last year, thought this was to cure a few hdcp probs. I know the z2 is compatable as I have heard from another user on another forum
Is this a hdcp problem?
Can it still be a length problem as more bandwidth is required for the higher resolutions?
I would be really grateful for any replies as until last night from what people say on here you can`t really see difference between hdmi and prog but standing next to the wall last night and switching between the 2 I can see quite a difference
thanks in advance
Stu
thanks in advance
Stu
