plv-z2 - official specs
Discussion in 'Projectors, Screens & Video Processors' started by pdgnews, Sep 2, 2003.
  1. pdgnews
    pdgnews
    Discovered this link over on avsforum:
    http://www.sanyo.de/produkte_eng/projektoren/lcd/produkt.asp?P_ID=94&ptyp=1
    PLV-Z2 Technical data
    Brightness: 700 ANSI lumens
    Panel System: 3 x 0,7" TFT p-SI
    Resolution: 1,280 x 720 pixels (HDTV)
    Computer Compatibility
    XGA
    S-VGA
    VGA
    Mac
    HDTV1080i
    720p
    lamp 130 W UHP
    Uniformity 90 %
    Contrast ratio 1200:1
    Digital keystone correction
    Vertical +/- 20 °
    Standard Objective
    F= 2,04 - 2,54
    f= 21,5 - 27,7
    Aspect Ratio 1,5 - 1,9 : 1
    Throw distance 1,2 - 6,1 m
    Color system
    PAL
    SECAM
    NTSC
    NTSC4.43
    PAL-M/N
    Frequence
    H. sync. 15 - 80 kHz
    V. sync. 50 - 100 Hz
    Dot clock 100 MHz
    Eco mode function
    Fan noise 26 dB
    Voltage 100 - 240
    Power consumption 210 watt
    Dimensions 359 x 97 x 274 mm width x height x depth
    Weight 4,2 kg
    Lens-shift-function
    horizontal, manual
    vertical, manual
    DRIT (Digital Realized Interpolation Technology)
    Plug & Play
    Power Mangement
    Video signal input 1: Signal (Input)
    S-Video (Mini DIN4)
    Component Video in
    Composite in
  2. magking
    magking
    Jan 6, 2001
    378
    Norway
    Thanks for the link:smashin:
    I think this might be my next PJ. I have a Panny AE100 now and have a buyer for that already.
    I'm going to the Event II in Guildford in November, anyone know a shop in the area that can give me a demo of it?
  3. PFM
    PFM
    Sep 24, 2000
    451
    Barton Upon Humber
    +17
    Prices anyone??
  4. SanPedro
    SanPedro
    Jan 11, 2001
    4,526
    +510
    Sounds yum.
    Resolution is astonishing. And the contrast ratio too. Let's hope the prices are keen.
    Chris L
  5. theritz
    theritz
    Aug 17, 2002
    2,451
    Ireland
    +27
    Sanyo themselves are talking around the 2000 euros mark, already seen reports of it advertised in France just below that level - This would point to it coming in around £1400 - this will be some achievement for a 1280x720 projector with the quoted CR level. I've seen video footage of it fired up - not possible to judge quality etc., but the lens shift funtion allows the image to be moved horizontally by half the image width, and fully by the image height vertically - very impressive. Adjustable iris function also clearly effective - lowering brightness, certainly, but with benefit for blacks.
    Earlier discussion here might be of further interest.
    Sean G.
  6. SanPedro
    SanPedro
    Jan 11, 2001
    4,526
    +510
    More like bloody amazing. I might be getting rid of my trusty old AE100 sooner than I thought :D
    Chris L
  7. Kramer
    Kramer
    Have you been looking through my videos again?
    Where did you see the footage if I may be so cheeky as to ask?
    I can see why the specs/price are causing such a stir, but I don't think this will be (to quote from The Matrix) "The One".
    May well be proved wrong, but...........
    :hiya:
  8. Peter G
    Peter G
  9. GrahamC
    GrahamC
    Jul 22, 2001
    2,258
    Morecambe, U.K.
    +67
    Nice Peter G:smashin:
  10. codling
    codling
    Jul 5, 2001
    427
    hartlepool
    +15
    hi all,
    when is it due for release and does anyone know the throw distance of it.
    cheers carl
  11. Wilster
    Wilster
    And earlier today I was psyching myself up to buy an ae300 over the weekend... a couple of hundred quid more for a 720p prj sounds like an absolute bargain!
    Kramer, what makes you think this prj isnt going to be 'The One'? Forgive me for questioning your judgement, but the specs suggest it will at least be an epson tw100 for a grand less!
    PS that video showing the iris and lens function... Im impressed enough to try and remember my highschool German :)
