PLV-Z1 and Syncblaster
Discussion in 'Projectors, Screens & Video Processors' started by stevelup, Dec 28, 2002.
  1. stevelup
    stevelup
    Aug 13, 2002
    6,507
    Swindon
    +1,080
    There was a message posted on here a while ago asking whether anyone has had any success using the Sanyo PLV-Z1 projector with a Syncblaster cable.
    The post seems to have been deleted for some reason...
    Anyway, I can't confirm whether or not the PLV-Z1 does work with the Syncblaster cable. I can - however - confirm that you don't need one at all.
    Simply buy a SCART -> 4 x BNC, and a normal PC VGA to 5 x BNC cable.
    Connect the two together as follows:-
    R->R, G->G, B->B and Composite Video -> Hsync. Leave the Vsync cable disconnected.
    It works perfectly. I have since made up a proper cable with about 15 metres of four core mini coax. On one end is a SCART plug, on the other end is a DB-15 VGA plug (totat b1tch to solder...)
    Regards,
    Steve
  2. BarryTra
    BarryTra
    Hi Steve I made up a cable following your instructions but there seems to be a black bar at the bottom of the picture, below that there is a frozen part of the image,Have you any ideas.Cheers
  3. stevelup
    stevelup
    Aug 13, 2002
    6,507
    Swindon
    +1,080
    I have no suggestions I'm afraid. It is working fine here.
    You are using this with your Panasonic DVD player?
    I have successfully used it with Tivo, Sky Digital and an XBOX. I will check it out with my Toshiba SD-220 DVD player in the morning.
    What happens when you toggle between the aspect ratios? Have you tried both region 1 and 2 disks? (I have only tried mine with 50Hz source material so far)
    Steve
  4. BarryTra
    BarryTra
    HI Steve
    I have tried it with 2 aspect ratios only 2 seem to work normal and full,the zoom does not work.It is where the black border is at the bottom. There seems to be a frozen image,but the picture is a lot better.
    I have used a vga lead with a scart on the other end,would it be better with a heavier cable.Thanks for you time.
