PLV-30 question
Discussion in 'Projectors, Screens & Video Processors' started by Weiman, Feb 27, 2001.
  1. Weiman
    Weiman
    Feb 25, 2001
    25
    Gothenburg, Sweden
    When you watch 16:9 material, can you adjust the vertical position of the 16:9 image within the 4:3 panel? I.e. move it down closer to the center speaker.
    /Johannes
  2. Vis Man
    Vis Man
    Feb 22, 2001
    207
    UK
    +10
    NO if you go down to far on the vertical shift you will start to lose your image
