plv-30 / on-digital
Discussion in 'Projectors, Screens & Video Processors' started by Chris Frost, Jul 4, 2001.
  1. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,783
    Cheshire
    +109
    fatrich,
    Can you get a picture with only the OnDigital box connected via the iScan to your projector?
    If so, then the solution is simply the priority switching on the iScan.
    Regards
  2. fatrich
    fatrich
    Jun 21, 2001
    2,617
    71
    halifax
    +53
    can any one advise me, the problem is that when i run my on-digital through my projector via a iscan box i can't get a picture.The dvd player is connected via component to component to the iscan then component to vga from the iscan to the projector.The on-digital is s-video out (via rgb-s-video converter)to s-video in to the iscan.The only time i can get a picture is when i change the cable from the iscan from vga out to vga in on the projector and put it in computer mode and switch the iscan to rgb.Every time i want to watch dvd or on-digital i will have to swap leads which is a bit frustrating.
    Can any one shed a bit of light on the problem
    thankyou
    fatrich
  3. fatrich
    fatrich
    Jun 21, 2001
    2,617
    71
    halifax
    +53
    chris
    thanks once again, but to save me waffling on can you tell me how you would bring the system together and what kind of cables to use.
    set up:
    sanyo plv-30
    pioneer 737 dvd
    nokia on-digital box
    Iscan pro
    pioneer vsa-e07 amp
    thankyou for taking the time out to help
    fatrich
  4. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,783
    Cheshire
    +109
    From what I read of your description I think you are wired correctly. There should be no need to change the iScan to projector lead. Your connection should stay as 15pin VGA to 3 phono, iScan set to component out, PLV30 set to component in.
    The other area to look at is the projector menu for progressive scan signal rate.
    There are several different settings; from 480i through to 1080i and Auto. Try changing to 5XXp when viewing Pal TV sources.
    Regards
