PLV-30 lamp life
Discussion in 'Projectors, Screens & Video Processors' started by StephenR, Sep 29, 2001.
  1. StephenR
    StephenR
    Jan 2, 2001
    296
    16
    Warrington
    I think this has been asked before, but as the search facility isn't working I hope you won't mind me asking again. I seem to recall that there is a way to see how many hours the lamp in a PLV-30 has done using a "secret" menu. The question is how do you access this?
    I am asking because the lamp replace indicator on my PLV-30 has come on and I don't think it has done anywhere near 2000 hours. Also the picture looks just as bright as it did when it was new.
  2. AlfaKhan
    AlfaKhan
    Aug 7, 2001
    250
    Cascais, Portugal
    +6
    Hi Stephan,
    To check the lamp hours press the "UP/TOP" point button (on the top of the unit) for about 30 seconds.
  3. StephenR
    StephenR
    Jan 2, 2001
    296
    16
    Warrington
    Thanks for that. As I though, my PLV-30 has only done 949 hours - so why has the lamp replace indicator come on? Shall I just ignore it? Can't do any harm, surely. I don't really want to send the projector back (and do without it) for something so trivial.
  4. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    It does no harm, or so i was told, except to the picture quality. You dont need to send it back to replace it, all you do is buy the bulb and fit it yourself, takes 5 minutes.
    ad
