Following a close escape involving a drill and a pipe in a wall I was prompted to go and find/check our internal stop tap... unsurprisingly it’s completely seized and needs replacing. I went looking outside for the main water stop tap but could only find water covers near the neighbours houses... I then found the water meter hiding in the garage.
There’s a tap either side of the meter... I turn them both off and the water from the tap comes out much slower but still flows... are one of these going to be the main stop tap or are they something else?!
The grey pipe that goes into the bottom tap comes from under the garage floor so I’m thinking that is from the mains? After the meter it goes to a tap in the garage, the washing machine feed and into the house.
There is what looks like a water meter hatch on the garage floor but unhelpfully the idiot we bought the house from relaid the garage floor and appears to have covered part of it...
Nothing surprises me with this place, most of the electrics and plumbing is a bodge job so I need to know I can turn the water off! I’m going to get a plumber to replace the internal stop tap but if one of the taps in the garage is the mains one I’m not sure how he can turn the water off?!
