Plugs for Denon 3802
Discussion in 'AV Receivers & Amplifiers' started by ramjam55, Jul 5, 2004.
Tags:
  1. ramjam55
    ramjam55
    Aug 6, 2003
    1,186
    Durham
    +27
    Does anyone know where I can get a plug that will connect to the back of the Denon 3802? It looks like a Euro connector (I think thats what it is). I looked through Maplins website but couldn't see one. I already have 13 devices plugged in and I would like to try and reduce this number so this is a good start.
  2. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    23,132
    2
    In a secret location with Jennifer Lawrence
    +10,022
    Not sure what you mean here, what connection on the 3802 do you want to connect to? as there are many!
  3. karkus30
    karkus30
    Jul 29, 2002
    13,997
    +1,236
  4. bobbypunk
    bobbypunk
    no it is just the european plug type for directly into the mains socket. Not sure where you'd get one. Some products come with one fitted (NAD and Sony for example are a european plug in an english plug adaptor)
