Plugging an MP3 player into AVR300
Discussion in 'AV Receivers & Amplifiers' started by technojunkie, May 18, 2005.
Tags:
  1. technojunkie
    technojunkie
    Jan 15, 2005
    196
    I want to plug my Creative Zen portable music player into my AVR300. The only output on the music player is the headphone socket. Which is the best input on the AVR300 to use and what should I set the input voltage too ?
    Thankyou for any helpful advice.
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,565
    Edinburgh
    +1,265
    You can plug it into any of the analogue inputs, it should not make any differecne which. You will need a 3.5mm mini jack to two RCA plug cable. Leave the input voltage as it is for just now. If you find you are having to turn the volume up higher than normal then adjust the input sensitivity as required.
  3. technojunkie
    technojunkie
    Jan 15, 2005
    196
    Thankyou Crustyloafer.
