Plug in audio/video modules for wall plates?
Discussion in 'Cables & Switches' started by Justhe1, Sep 6, 2004.
  1. Justhe1
    Justhe1
    Apr 5, 2003
    46
    Hatfield, Herts
    Hope this is the correct place for this email..
    I have just purchased a Panny 42 plasm c/w a load of items and now wish to connect via wall plates my amp's 2nd Room ouputs, and 2 co-ax outputs to my Dining room Amp& LCD.
    I have cut out a double gagng width hle in the brickwork of both front Room and Dining Room (back to back) and have purchased 2 off QED brushed Steel wall plate surrounds from Richards AV in St Albans.
    My question is where is the most cost effective place to purchase the "inserts"? - From what I can tell I can only find complete plates and I only need the modules...
    I will need in total 2 sets of female banana type plugs for audio (L&R), 2 sets of Phono L&R for amp to amp connectivity and 2 of co-ax or sat type connections - but all as plug in module type...
    Can anyone point me in the right direction please as I'm struggling bigtime :confused: (this is my 1st multi room connection attempt!)
    Any advise/links greatly received...
    J
  2. newstuart
    newstuart
    Apr 22, 2004
    1,797
    Northumberland
    +82
    Keene electronics used to,havent looked recently though may be worth a try :thumbsup:
  3. Justhe1
    Justhe1
    Apr 5, 2003
    46
    Hatfield, Herts
    Cheers Stuart,
    Will have a looksee :)
